2004 toyota sienna keysense/disarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129421
Printed Date: April 12, 2026 at 6:45 AM
Topic: 2004 toyota sienna keysense/disarm
Posted By: mb07
Subject: 2004 toyota sienna keysense/disarm
Date Posted: November 28, 2011 at 9:05 AM
Hi everyone..  regarding the keysense and disarm wire the 04 sienna has, I will be putting a Compustar 6200S starter brain along with a Fortin key override SL2 bypass.  The bypass wants a wire to go to keysense which is fine.  Does this mean I do not hook up the programmable keysense/glow plug input (BROWN / white) wire from the compustar to it as well and the fortin does it for me?  Thanks in advance!
Posted By: Chris Luongo
Date Posted: November 29, 2011 at 6:49 AM
I'm pretty sure the Fortin module uses the light green keysense wire only as an input for programming, but not as an output.
So you would still have to also connect an output from your Compustar that makes a ground the entire time the remote starter is on, so that the Toytota alarm will disarm.
P.S. You have already tested that this particular Sienna does have a factory alarm, right? Most of them don't.
Posted By: tedmond
Date Posted: December 01, 2011 at 8:29 AM
if you had the key override all, the keysense is used for programming and will supply ground as well when activated for RS.
Ted
Compustar Expert
