’02 tundra python 533
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129467
Printed Date: April 10, 2026 at 1:53 AM
Topic: ’02 tundra python 533
Posted By: elfyyy
Subject: ’02 tundra python 533
Date Posted: November 30, 2011 at 8:34 PM
If any of you could take the time to help me, that would be the greatest thing ever!!! So on cyber Monday I ordered a python 533 for $109 plus a window roll up, tilt sensor, and glass break sensor. I am very well versed in electronics and car audio but never have done a remote start... So, i understand the whole install process and seems pretty basic but I need to understand which few wires go to what... So here it goes!!! Here is my wiring Diagram for my 02 Tundra....
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|WHITE/ red or white |+ |ignition harness            |
|          STARTER|GREEN/ black        |+ |ignition harness            |
|        IGNITION|BLACK / YELLOW        |+ |ignition harness            |
| SECOND IGNITION|BLACK/ red           |+ |ignition harness            |
|        ACCESSORY|blue/red            |+ |ignition harness            |
|       POWER LOCK|WHITE/ green        |- |either kick panel           |
|     POWER UNLOCK|RED / yellow          |- |either kick panel           |
|       LOCK MOTOR|blue/white          |   |drivers door harness        |
|     UNLOCK MOTOR|BLACK / YELLOW        |   |drivers door harness        |
|    DISARM DEFEAT|RED / yellow          |   |drivers door harness        |
| PARKING LIGHTS +|green|   |drivers kick panel          |
| PARKING LIGHTS -|RED / black           |   |steering column             |
|       HEADLIGHTS|GREEN/ YELLOW        |- |steering column             |
|     DOOR TRIGGER|WHITE/ blue          |- |drivers door harness        |
| DOME SUPERVISION|use door trigger    |   |             |
| FCTRY ALARM ARM|     |   |             |
|FCTRY ALRM DISARM|blue/black          |- |drivers door harness        |
|       TACHOMETER|black or blu/wht *1 |   |instrument cluster, brn plug|
|      SPEED SENSE|GREEN/ orange        |4k |instrument cluster, brn plug|
|       BRAKE WIRE|GREEN / WHITE        |+ |drivers kick panel          |
|     HORN TRIGGER|GREEN/ red           |- |steering column             |
|           WIPERS|blue/black          |+ |steering column             |
| LF WINDOW UP/DN|lt. grn - blu/yel   |A |drivers window switch       |
| RF WINDOW UP/DN|RED / blk - RED / grn   |A |drivers kick panel          |
|        RADIO 12V|blue / YELLOW        |+ |radio        |
|     RADIO GROUND|brown|- |radio        |
|     RADIO SWITCH|gray |+ |radio        |
| RADIO ILLUMINATE|green|+ |radio        |
|    POWER ANTENNA|     |   |             |
|       LF SPEAKER|pink - purple       |   |radio        |
|       RF SPEAKER|green - blue        |   |radio        |
|       LR SPEAKER|black - yellow      |   |radio        |
|       RR SPEAKER|red - white        |   |radio        |
Im will post a reply to space it out!!!! Thanks!!!!!
Posted By: elfyyy
Date Posted: November 30, 2011 at 9:27 PM
Now If your still with me thanks!
So these following wires I am going to be typing from my manual and I don't know which it would be on my truck. If you could just tell me what item it is I would be so thankful!!
(-)Remote Start activation input-
(-)unlock(+)Lock output-
(-)Lock(+)Unlock output-
(-)200mA Programable Ign2/acc2 Relay turn on-
(+)Ignition input to alarm-
(-)200mA Ignition relay turn on-
(-)Accessory relay turn on-
(-)200mA Starter Relay turn on-
(-)500mA Anti Grind/Ground when armed output-
(-)200mA Status Output-
(-)Output to accessory Circuit-
Output to primary Ignition Circuit-
Output to Secondary Ignition Circuit-
(+)(30A)High current 12v Input-
Posted By: elfyyy
Date Posted: November 30, 2011 at 10:16 PM
NEVERMIND THIS THREAD!!!!!!! I just realized I'm very dumb and forgot to read one part of the manual!!!!
