2011 sierra remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129572
Printed Date: April 08, 2026 at 2:13 AM
Topic: 2011 sierra remote start
Posted By: emt04401
Subject: 2011 sierra remote start
Date Posted: December 07, 2011 at 8:38 AM
Need help have diagram to ad relay to by pass multip ignition but didnt work what am i doin wrong everthing lights up ontruck just no start is it possable to bypass this ignition ? Got diagram grom victorytechnologies gm remote startviintegration
Posted By: emt04401
Date Posted: December 07, 2011 at 8:44 AM
It states ...... 87a to starter2/accessory 1 wire on ign switch cut wireto switch
86 12v
30 to the other cut end of starter2/accessory 1 wire
85 to ground when started output from aftermarket starter ( i thnk this is where i messed up now )
It also says to tie in starter output from aftermarket starter with 9.6k res and tie into cut wire that goes to bcm (starter2/accessory1wire on bcm side
And also accessory 2 output from sftermarket starter with 6.3k res to same cut wire as stated above
Posted By: emt04401
Date Posted: December 07, 2011 at 8:47 AM
Feel free to call need help asap truck apart .....also using the bulldog rs2ba basic starter hooked up prob 50 and this ones got me for some reason thanks in advance
