viper 5902 with 516l voice module
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129606
Printed Date: April 07, 2026 at 10:27 PM
Topic: viper 5902 with 516l voice module
Posted By: jvt6
Subject: viper 5902 with 516l voice module
Date Posted: December 09, 2011 at 8:17 AM
Hi,
I have a Viper 5902 and have the 516l Voice module. Since the shock sensor is built in to the 5902 brain, I don't see a 1st and 2nd stage output wire for the sensor so that I can connect it to the warn away input on the 516l Module. Is there a way to wire it so instead of the warn away chirps, it would go to the warn-away input to the voice module? Or do I need a separate shock sensor to make this work?
Thank you in advance for your response.
Posted By: howie ll
Date Posted: December 09, 2011 at 9:20 AM
Separate shock, by the way the 516 is a kludge, is it really worth trying to install it?
You'd be better off just adding a 508d, simpler and more reliable.
Posted By: jvt6
Date Posted: December 10, 2011 at 7:55 AM
I figured that a separate sensor is the only way. Looks like the 508 it is. It would be useless to add another shock sensor.
I agree that the 516 is a kludge. I was disapointed when i read the install manual but I already ordered it. So I installed it anyway.
Thanks for your inputs Howie II
