tbxkey not working on cold starts
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129675
Printed Date: April 04, 2026 at 9:51 AM
Topic: tbxkey not working on cold starts
Posted By: jeff262
Subject: tbxkey not working on cold starts
Date Posted: December 12, 2011 at 11:52 PM
2011 ford focus using a TBXKEY, key in the box, it doesn't work after a overnight cold start, below 32 degrees after 14 hours. anyone have any idea why or a better bypass for the focus
thank jeff
Posted By: tedmond
Date Posted: December 13, 2011 at 12:32 AM
use a data bypass and save the key.
ADS-AL CA by idatalink
EVO-ALL by Fortin Electronics
both are very reliable pieces. i have used both on the 2011 focus with no problems.
Ted
Compustar Expert
Posted By: kreg357
Date Posted: December 13, 2011 at 3:34 AM
X 2 with Ted.  A Data type bypass is more reliable than RF.  Fortins'  EVO-Ride is another Data type bypass choice.
You could also try re-positioning the antenna loop on the ignition switch and / or going to the "60 Windings" jumper position in the TBXKey box.
Posted By: jeff262
Date Posted: December 16, 2011 at 8:16 PM
still nothing with changing the position of the loop on the ignition and changing the windings jumper. just went with the EVO-RIDE. funny as soon as the key hit 38 degrees inside the box it would just stop working
thanks jeff
