2001 continental
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129726
Printed Date: April 04, 2026 at 2:12 AM
Topic: 2001 continental
Posted By: prdjr165
Subject: 2001 continental
Date Posted: December 16, 2011 at 6:25 PM
The rx and tx wires in the lincoln continental don't match what fortin says and the module (key override all) won't program.the wires in the car at the pats module are:
1-brn/wht
2-vio/blue
3-RED / blk
4-tan/orange
fortin says - rx-brn/yell tx-gray/red
Posted By: metz35
Date Posted: December 16, 2011 at 6:54 PM
3 rx 4 tx
Posted By: prdjr165
Date Posted: December 16, 2011 at 8:24 PM
thanks!got it starting but now service engine soon light is on and check traction control is on the message center.
Posted By: chev104275
Date Posted: December 16, 2011 at 9:04 PM
You missed an ingition or acc wire
Ignition 1 BROWN / PINK (+) IGNITION SWITCH HARNESS
Ignition 2 GRAY / YELLOW (+) IGN SWITCH HARNESS
Accessory 1 BLACK/ LIGHT GREEN (+)
If I remember right there are 2 gray / YELLOW wires
------------- If i Can't Install it I Don't need it Joe
Posted By: prdjr165
Date Posted: December 17, 2011 at 3:53 AM
I was thinking the same thing,I might have the 2nd ignition wire jumper on accy. I will have to get the car back to check it out.
Posted By: prdjr165
Date Posted: December 22, 2011 at 1:11 AM
costumer said that the traction control light was already on,the obd11 codes are P0500 and U1039,these codes suggest that the ignition switch chime switch is defective,anyone experiance this before?
Date Posted: December 22, 2011 at 8:42 AM
Did the little metal tab break when you took the shroud off or when you put the bypass ring in
Posted By: prdjr165
Date Posted: December 22, 2011 at 11:13 AM
i didn't pull the ignition switch out,I used a key override all without a transponder ring.I didn't notice any little metal tab breaking.I am getting the car back friday afternoon and plan on replacing the chime switch and hope that takes care of the service engine soon light.
Posted By: prdjr165
Date Posted: December 23, 2011 at 8:51 AM
has anyone actually found the grn/vio dis-arm wire in the dr kick of this car?found one grn/vio in the dr door boot but it didn't dis arm the alarm.
Date Posted: December 23, 2011 at 12:43 PM
There should be a GREEN/ violet disarm wire at the lcm on the right hand side of the steering column
Posted By: prdjr165
Date Posted: December 23, 2011 at 2:38 PM
I tries the LCM to,there isn't a grn/violet wire on there.I just might have to go in the drivers door:(
Posted By: prdjr165
Date Posted: December 23, 2011 at 6:33 PM
replaced the ignition chime switch and connected the second gry/yell accy wire and reset the service engine soon light,so far so good.
