2009 honda crv auto window roll up
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129874
Printed Date: May 16, 2026 at 4:05 AM
Topic: 2009 honda crv auto window roll up
Posted By: deeryders
Subject: 2009 honda crv auto window roll up
Date Posted: December 26, 2011 at 8:49 PM
I have recently put in a Viper 5901 with a DEI 529T window roll up module. Everything is working out fine expect for the drivers window. More then often once the window is rolled down you loose control and it winds back up and you are not able to control the window anymore until about an hour or if the the cars turned on and off again. All the other 3 windows work fine and i ruled out the fact that it is a bad module because the passenger side window works fine. I do not understand. the only thing different about the windows is that the driver side window is an Auto Roll up and down window from the dealer. You guys have any advice.
Posted By: howie ll
Date Posted: December 27, 2011 at 3:09 AM
Did you wire the driver's side at the two wires going to the motor.
Check the 529t orange GWA trigger wire. Is this grounding when going over bumps?
Did you install the 529t in the driver's door, if so is it grounded to the window switch ground, fed back to a bolt in the car or a bolt in the door. The 3rd. option is unacceptable, re-wire.
