compustar cm6000, 2005 trailblazer
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129932
Printed Date: May 16, 2026 at 12:18 PM
Topic: compustar cm6000, 2005 trailblazer
Posted By: naviracer23
Subject: compustar cm6000, 2005 trailblazer
Date Posted: December 29, 2011 at 4:10 PM
So tomorrow I'll be doing my 3rd remote starter in a 2005 Trailblazer and had just a few questions. I'll be using the AL-CA with the vehicle so I'll be running in data mode.
1) This vehicle needs the 2nd accessory at the ignition harness to be powered up, so do I use the 2nd accessory output from the white 20-pin harness to do that? If so, should I use a relay?
2) Do I need to use a relay for horn or parking light output?
Posted By: metz35
Date Posted: December 29, 2011 at 5:13 PM
The vehicle needs the second ignition powered
Yes u need a relay
Positive parking lights
Negative horn
Date Posted: December 29, 2011 at 5:20 PM
Do I also need a seperate relay for parking lights and horn?
Posted By: metz35
Date Posted: December 29, 2011 at 5:31 PM
You should have positive parking lights on that unit --GREEN / WHITE
And the horn should be a negatitive. --White
Date Posted: January 14, 2012 at 6:44 PM
Can someone familiar with compustar remote starters call me asap at 715-571-5242 thanks!
Posted By: offroadzj
Date Posted: January 14, 2012 at 9:07 PM
I can't call you but you are welcome to post any issues on here and we can try to help.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Posted By: tedmond
Date Posted: January 14, 2012 at 9:24 PM
We have compustar dealers here using the board, such as Metz and myself, if you got compustar questions post it here (as Kenny suggested) , and I'm sure we can direct your questions
Ted
Compustar Expert
Date Posted: January 14, 2012 at 9:26 PM
I have recently started using Compustars as well.. and have gotten pretty accustomed to them... so I'm sure any of us can help you once you post up your issues.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Posted By: tedmond
To your question on the white 20pin harness take the second negative ignition output (-) connect to a relay which is given
85 negative ignition
86 constant 12v fused
87 constant 12v
30 second ignition wire on vehicle
87a unused
Ted
Compustar Expert
Posted By: metz35
Date Posted: January 15, 2012 at 6:28 AM
Parking lights positive straight connection from remote start with the large GREEN / WHITE to brown in the car no relay
Horn Negative straight connection from remote start small white to black in the car no relay
Also hardwire the tach as that car has issues with a data tach. Yellow/ black from
Remote to white in the car. If you dO not hardwire tach eventually you will start to get get error code 1-3 which is an already running code/no tach programmed code
Date Posted: January 15, 2012 at 9:47 AM
If you want you can use the (-) parking light output (smaller gauge GREEN / WHITE). It will help give 1 less fuse in the bundle to tuck away and its 1 less thing drawing from the power source.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
