autostart 7 flashes
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129944
Printed Date: May 16, 2026 at 3:02 PM
Topic: autostart 7 flashes
Posted By: maxcat
Subject: autostart 7 flashes
Date Posted: December 30, 2011 at 9:31 AM
hi guys, have a buddy that just bought a vehicle with what appears to be an older 4 button autostart. lock and unlock buttons still work but the vehicle park lights flash 7 times upon presssing the start button. tried to look up the diagnostics on the autostart site, found almost everything BUT 7 flashes. Just wondering if this might be valet mode or tach lockout or maybe it needs a 2 button start sequence.
 If anyone happens to know what the 7 flash error code means or has any ideas they would be greatly appreciated
 Thank you in advance
Posted By: shortcircuit161
Date Posted: December 30, 2011 at 10:11 AM
It depends on the model of the unit. Do you have a model number? Some of the Autostart manuals I've seen show 3 flashes as being a tach issue.
Date Posted: December 30, 2011 at 10:21 AM
Is it installed on an automatic or manual trans vehicle?
Posted By: maxcat
Date Posted: December 31, 2011 at 7:27 AM
I dont yet have a model #, the vehicle is an automatic. I also looked for a valet switch as I know some of the old autostarts had a small toggle switch for  valet.
thanks for the reply I will keep digging
