07 honda oddessy
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129946
Printed Date: May 16, 2026 at 4:09 PM
Topic: 07 honda oddessy
Posted By: 4trxrd
Subject: 07 honda oddessy
Date Posted: December 30, 2011 at 12:13 PM
Just installed a avital 4103 remote start keyless system with a db all bypass module , what I get is random starts it will crank and start and other times it will just crank and not start ,checked ign wire is ok on all remote start times no second ign wire that I can see ,also tried different db all module same results any help wounld be great
Posted By: offroadzj
Date Posted: December 30, 2011 at 12:50 PM
how do you have the engine sensing programmed. It sounds like you either have a sensing issue or a bypass issue... but my bet is on sensing. Did you connect a hard line tach signal?
------------- Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Posted By: 4trxrd
Date Posted: December 30, 2011 at 3:27 PM
I used the virtual tach sens looked like the hardwire was going to messy , ign wire test 12v before crank and 10v while crank thanks
Date Posted: December 30, 2011 at 9:05 PM
connect the tach wire and reprogram the unit and the tach signal... I believe that will solve your problem. Messy or not, its always better to do it the right way the first time.
------------- Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
