08 tundra air bag light
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129947
Printed Date: May 16, 2026 at 5:03 PM
Topic: 08 tundra air bag light
Posted By: ziggyb222
Subject: 08 tundra air bag light
Date Posted: December 30, 2011 at 3:25 PM
Installed a 4103 Avital in a 08 Tundra with and xk05 bypass.. Connected 12v to thick black wire at fuse box.. dark green to starter light green ignition 1 black ignition 2 and gray for acc... all 22 guage wires from the switch.... In remote start I get a air bag light and a tire pressure monitor light.. on key take over those lights do not go out. you need to shut the truck down and restart with the key.. when starter with a key there is no lights at all.. Tried swapping ignition wires no luck.. Also had a problem getting the remote into program mode.. I would assume there is a messed up ign or acc wire.. ignition wires tested fine.. HELP I need to get this truck wrapped up.. Thanks in advance!!!
Posted By: shortcircuit161
Date Posted: December 30, 2011 at 3:33 PM
If you start it with the key and try to have the Avital take over and remove the key, do the lights also turn on? And you've tested all your ignition connections to ensure that the pink/white cable from the Avital was programmed correctly to 2nd Ignition?
Date Posted: December 30, 2011 at 3:50 PM
Generally a dash light comes on (such as airbag, check engine, etc) if an ignition/2nd ignition wire isn't getting power when the starter is engaged to start the truck. Therefore, the test I suggested before may not light the airbag and tire pressure lights, because it was started with the key that did power both ignition wires upon starting it. Hope that makes sense.
Date Posted: December 30, 2011 at 4:55 PM
Thanks for your replies... I tripple checked everything and determined I had a cold soldered joint on the 2nd ignition wire... soldering to the small wires I did not get a good connection. Lesson learned and all is fine now.. Thanks again for your suggestions it prodded me to check things over again!!!!!
Date Posted: December 30, 2011 at 5:12 PM
Glad everything worked out. Enjoy it!!
