2006 chevrolet w 3500 box truck
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=129966
Printed Date: March 31, 2026 at 2:25 AM
Topic: 2006 chevrolet w 3500 box truck
Posted By: ricardoboston
Subject: 2006 chevrolet w 3500 box truck
Date Posted: December 31, 2011 at 3:04 PM
hi happy new year,for all,guys need a wiring diagram for remote starter on this work truck please asap, i will try to put a remote starter on this truck ,i dont have any idea if it works or not ,i will be happy if you guys can help me out here thanks again
Posted By: kreg357
Date Posted: January 01, 2012 at 7:17 PM
This info from Audiovox for 2006 Silverado 3500. Looks like a standard GM full size pick-up. Passlock2 immopbilizer system. Remote Start WIRE COLOR POLARITY LOCATION Battery RED (+) IGNITION SWITCH HARNESS Ignition 1 PINK (+) IGNITION SWITCH HARNESS Ignition 2 WHITE (+) IGNITION SWITCH HARNESS Accessory 1 ORANGE (+) IGNITION SWITCH HARNESS Accessory 2 BROWN (+) IGNITION SWITCH HARNESS Starter 1 YELLOW (+) IGNITION SWITCH HARNESS Anti-Theft Type PASSLOCK II Anti-Theft Descript A RESISTANCE BASED SYSTEM Key Sense LIGHT GREEN (-) AT STEERING COLUMN HARNESS Tachometer WHITE (-) AT INSTRUMENT CLUSTER CAN ALSO USE ANY FUEL INJECTOR OR IGNITION COIL, ON DIESEL MODELS, THE TACH WIRE IS IN THE GRAY PLUG, PIN 37. Speed Sense DK GREEN / WHITE (AC) PCM MODULE AT LEFT FRONT SIDE OF ENGINE COMPARTMENT Parking Lights VIOLET (-) AT VEHICLE LIGHT SWITCH Parking Lights GRAY/BLACK (-) AT LIGHT SWITCH OR BROWN PLUG AT BCM PIN B2 Brake Lights WHITE (+) AT BRAKE PEDAL SWITCH Reverse Lights LIGHT GREEN (+) BCM BLACK PLUG PIN F Horn BLACK OR BLACK / YELLOW (-) AT STEERING COLUMN HARNESS
Verify with DMM.  ------------- Soldering is fun!
Date Posted: January 01, 2012 at 7:28 PM
Date Posted: January 01, 2012 at 7:33 PM
thanks kreg this is what i have test WHITE/ black power 12v ,BLACK/ white start, blue ign , BLACK / YELLOW acc the others 3 wires i dont know how to get it connected to a bypass and with one to use blue/white,blue,blue / YELLOW
Date Posted: January 01, 2012 at 7:42 PM
sorry i up load both same pic now im up load the other one sorry
Date Posted: January 03, 2012 at 6:17 AM
hello everyone , please need to figure out it ,if this truck has any kind of theft ,i know for sure it will not start ,just crank ,crank that's all,so i have 3 wires ,blue/white,blue,blu / YELLOW, probaly its a some kind of passlock??? just dont know with bypass to use on it please some help here ASAP thanks
