viper smart start truck active while
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=130102
Printed Date: April 11, 2026 at 11:41 AM
Topic: viper smart start truck active while
Posted By: veiloctane
Subject: viper smart start truck active while
Date Posted: January 07, 2012 at 9:27 PM
question: are the viper 5902 + smart start functions still enabled while the car alarm is disabled and engine running?
I notice a trunk release button and I would like to wire that to a ignition kill with a relay to blow a fuse so that the car will not start again even with the remote.. for example carjacking situation or if someone steals your remote i can simply hit the trunk release to kill ignition??? does it sound possible can it be done?
Posted By: offroadzj
Date Posted: January 08, 2012 at 12:44 AM
I would highly recommend against trying to purposely blow a fuse. You would have to short the circuit and if the fuse ever didn't blow for whatever reason you could find your car burning down instead of just getting stolen. You would be better off trying to use a latching type relay setup that would open the ignition wire with the trunk release then reconnect the circuit with a second press of the trunk release. That would be a much safer wiring setup.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
