swap standard keyless entry with aftermar
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=130123
Printed Date: April 12, 2026 at 12:19 PM
Topic: swap standard keyless entry with aftermar
Posted By: archsu
Subject: swap standard keyless entry with aftermar
Date Posted: January 09, 2012 at 10:54 AM
I bought a 1998 Cherokee XJ with standard equipped keyless entry but did not get the remotes. i was wondering if I could swap the circuit board by the dome light with an aftermarket circuit board.
Thanks,
Sam
------------- archsu
Posted By: tedmond
Date Posted: January 09, 2012 at 11:51 AM
youre better off buying a keyless entry or remote start with keyless entry, then wire it up. easy vehicle to work on
------------- Ted
Compustar Expert
Posted By: howie ll
Date Posted: January 09, 2012 at 5:50 PM
Or go to a Chrysler dealer for the remotes except the aftermarket KE will probably be cheaper.
Have you tried a wreckers yard? Except you're unlikely to get two remotes.
Posted By: archsu
Date Posted: January 10, 2012 at 10:20 AM
thanks for your reply. do you know if the wires that are attached to the current wireless entry are the same wires i need for the new system?
Posted By: howie ll
Date Posted: January 10, 2012 at 10:34 AM
Look at my signature lines.
Actually extremely unlikely probably a mux (resistive) single GREEN / WHITE control wire, the resistors would be built into the OEM unit, you would have to add them.
Posted By: howie ll
Date Posted: January 10, 2012 at 10:38 AM
ORANGE / purple and pink/purple, both neg, driver's kick panel.
