2009 nissan sentra w/ intelli key locks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=130153
Printed Date: March 11, 2026 at 8:10 PM
Topic: 2009 nissan sentra w/ intelli key locks
Posted By: ILuvItLoud
Subject: 2009 nissan sentra w/ intelli key locks
Date Posted: January 11, 2012 at 10:06 AM
Installing an Autopage alarm in a 2009 Nissan Sentra with intelli-key.
I have installed alarm/remote combos in 5 vehicles to date, but this one is a doozy...
I cannot get the doorlocks to work. I believe I have found the right wires and tested them with a meter. I think my problem comes down to the disarm wire. I found a light blue wire in the kick panel coming from the door that I tested while turning the key. The bulldog website says "blue to white". Not sure what that means.
I hit the unlock button on the remote and I hear the relays click in the brain, but no dice. It states that the vehicle needs a double-pulse and I programmed it for that.
Anyone done an install on this car that can tell me what they did that worked?
Posted By: tedmond
Date Posted: January 11, 2012 at 11:24 AM
use a data bypass and that will solve all your issues/make your install easier. you have the wrong lock and unlock wires.
Lock RED / silver dots (-)@ dkp harness coming in from door
Unlock PINK/Silver dots (-) @ dkp harness coming in from door
Disarm BLUE TO WHITE (-). This simple means its a blue wire in the door, but after entering the vehicle through the connector, the wire changes to white in colour. Driver Kick Or BCM, White 40 Pin Plug, Pin 7
------------- Ted
Compustar Expert
Date Posted: January 11, 2012 at 4:11 PM
The help with the disarm wire is great, thank you. I am using a DLPK...my bro picked out the alarm, I have to do w2w to make it work. I am using those doorlock wires already....I think the disarm white wire is the key!
Posted By: tedmond
Date Posted: January 11, 2012 at 4:15 PM
yes you need the disarm wire to unlock the car. single pulse to disarm, double pulse to unlock all doors.
------------- Ted
Compustar Expert
