remote start 2007 chevy malibu anti gri
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=130181
Printed Date: April 24, 2026 at 10:58 PM
Topic: remote start 2007 chevy malibu anti gri
Posted By: benjf3
Subject: remote start 2007 chevy malibu anti gri
Date Posted: January 13, 2012 at 1:12 AM
Will be picking up a 2007 Chevy Malibu for Remote Start/Keyless Installation. I did some research on the vehicle and the intall is pretty straight forward with a databus module handling most functions. My concern is that the vehicle doesn't have a typical Starting System with a Starter wire and I'm looking for input on how (or which wires) to use to install an Anti-Grind. I have been including Anti-Grind options as standard with all my Starter installs as most people love this option. I did look for an AP8 RPO Code for a Factory Add On, but this vehicle doesn't have that option and I've found most aftermarket Starters outperform the OEM ones, especially in range.
So, if anyone could give some guide as to how an Anti-Grind is wired into this vehicle, it would be greatly appreciated! Any other pointers or tips are appreciated as well! Thanks.
Posted By: corlon
Date Posted: January 13, 2012 at 4:05 AM
i believe this vehicle has a built in anti grind circuit from the factory. give it a try before you being your install.
------------- nice...
Posted By: benjf3
Date Posted: January 13, 2012 at 6:26 AM
Thanks, I was thinking that based on what I've seen of the ignition for the data bus install. I'll know in a week once I have the car..
Posted By: tedmond
Date Posted: January 13, 2012 at 8:23 AM
no need for antigrind, the vehicle has one. the system MUX or multiplex. You can do a partial start (bump the starter), and the vehicle will continue to crank and start the vehicle.
likewise when it has been started, the starter is diabled
------------- Ted
Compustar Expert
Posted By: Mark Mizenko
Date Posted: January 13, 2012 at 8:50 PM
Want a little tip? Just do Ign. And Acc. At the switch, and a key in a box. Thats all that car needs. Save the fancy interface, and fooling with those "resistance" wires.
Posted By: benjf3
Date Posted: January 13, 2012 at 10:01 PM
That might be fine for some, but I don't want to give up the rest of my feature set or an ignition key. This is the reason I stopped using local shops, they were taking the cheap way out and charging a premium. This method may be fine for some, but I intend on interfacing with the trunk, factory alarm, and door locks. The easiest way I found to do this was with a data module which will handle all those resistance values.
Posted By: zerepdivad
Date Posted: January 13, 2012 at 10:57 PM
Horrible tip. This isn't the 90's anymore. Key in a box on a car like this makes me think the installer has a mullet. ------------- A DMM is a beautiful thing.
Date Posted: January 29, 2012 at 10:17 PM
I only specified what the car needed to start. And I didnt say anything about how much to charge someone.
Shoddy work, ripoff. What'ya work at best buy?
Posted By: benjf3
Date Posted: January 30, 2012 at 6:05 AM
Actually, I checked with a GM dealer and even though this car doesn't show an AP8 RPO Code it is listed via the dealer by VIN # as taking the factory add onn start. I can get the kit for $135 (same as I'd spend for a quality start unit and data module) and they can activate it for .6 hour labor charge whereas I'd have to burn a few hours wiring in the aftermarket one. I'll probably go that route, but thatnks for the postings.
Posted By: kreg357
Date Posted: January 30, 2012 at 6:19 AM
Not positive but some of the GM remote start systems have some p< size=3 face="Times New Roman">eculiarities, like a 10 minute run time with only one extension. Might want to check on that. Also the range isn't as good as most aftermarket systems, if that is important for your use situation.
------------- Soldering is fun!
Posted By: benjf3
Date Posted: January 30, 2012 at 6:38 AM
Yes, GM factory remote start has two 10 minute run times total before an ignition reset is needed. The range of the basic FOB right now is giving me the distance I need and the replacements are supposed to give you four times that range (approx 800 ft compared to the current 200ft). These are drawbacks, but overall will work for where and how this vehicle will be used with the bulk of remote starts occuring in the driveway. It's mainly to be done as a time saver and I clocked the "heat up" time of this engine at around 5-8 minutes so a 10 minute run is OK. If I wasn't satisfied with the functions, I'd go aftermarkter with a Code or CompuStar.
Posted By: tedmond
Date Posted: January 30, 2012 at 11:54 AM
i wouldnt use the oem stuff, i would rather go aftermarket. with the right module, install would be under an hour.
------------- Ted
Compustar Expert
