design tech range issue
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=130263
Printed Date: May 06, 2026 at 4:42 PM
Topic: design tech range issue
Posted By: chev104275
Subject: design tech range issue
Date Posted: January 17, 2012 at 4:28 PM
I made the mistake Saturday taking a customer supplied system to Install. It was a design tech deluxe. First tip should have been it came with a VHS tape so im sure it sat somewhere for a long time (when is the last time you saw a VHS tape) but the customer came back today saying out worked good for the first 2 days. But now you have to be right on the car for it to work. I went and tested it and she is right you almost have to sit in the drivers seat for it to work. Tried putting new batteries inthe remotes and same problem, unplugged and tried to reset module neither fixed it.
Any ideas ?
Posted By: offroadzj
Date Posted: January 17, 2012 at 4:32 PM
Check the antenna connections to make sure they are tight. If so then its probably either a bad antenna or a bad remote... no easy way to tell which one.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Posted By: tedmond
Date Posted: January 17, 2012 at 4:35 PM
check for a pinched antenna cable, try removing power and grounding it elsewhere.
Ted
Compustar Expert
Date Posted: January 17, 2012 at 8:54 PM
The antenna wire is ok as far as the connection its an RCA plug plugged all the way in she got mad and left so I cant check the power or ground.
I told her when I put it in there was no warranty and that I thought it was an old cheap system.   That aside I wouldve liked to check the ground its on a bare metal bracket next too the steering column thats welded to the rest of the dash frame
Date Posted: January 17, 2012 at 9:19 PM
Is the dash frame welded to the chassis? On some vehicles it is only bolted and on a rare occasion it is bolted through a rubber mount to allow movement. If she returns I would check the resistance between the ground at the unit and the battery.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Date Posted: January 18, 2012 at 7:47 AM
Good idea it looked to be directly welded to a flange then bolted to the body. If she comes back im thinking I will move the ground to a different location and give that a try
