2006 caravan ads al ca no start?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=130277
Printed Date: May 06, 2026 at 1:31 PM
Topic: 2006 caravan ads al ca no start?
Posted By: bruc007
Subject: 2006 caravan ads al ca no start?
Date Posted: January 18, 2012 at 9:55 AM
Hey,I am having troubles with a 2006 caravan and am using the idatalink ads-al ca module. Everything appears ok as far as wiring yet on remote start the ign powers up but no start.I am using D2D as opposed to wire to wire. Moduled programed correctly yet no starter crank. The module looks after second start. I have ign and starter wires hooked up and ran power to battery. Any help would be great
Bruce
Posted By: offroadzj
Date Posted: January 18, 2012 at 10:02 AM
What remote start are you using?
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Posted By: bruc007
Date Posted: January 18, 2012 at 10:09 AM
It is an basic Autostart model,which I have used a lot and it seems to be programmed correctly.just wondering about D2D versus wire to wire
Powers up -no crank
Date Posted: January 18, 2012 at 10:14 AM
I personally always go w2w for reliability. The DEI units can be very touch and go with d2d. Also, in order for the idatalink to work with the DEI d2d it has to be flashed with a certain firmware.(DBI-AL(DL)-CH6 instead of ADS-AL(DL)-CH6) Do you know what the AL-CA is flashed with currently?
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Posted By: bruc007
Date Posted: January 18, 2012 at 11:13 AM
I flash my own modules and this unit is flashed for ADS-AL(DL)-CH6)
Date Posted: January 18, 2012 at 11:35 AM
In order for it to work D2D with the DEI unit, it must be flashed with the DBI-AL(DL)-CH6 or you can just change to w2w which is more reliable anyways.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Posted By: bruc007
Date Posted: January 18, 2012 at 12:17 PM
I will try W2W tonight if that doesn't work I will reflash with DBI-AL(DL)-CH6 and let you know how it works
Posted By: tedmond
Date Posted: January 18, 2012 at 4:48 PM
i would flash it with the DBI firmware, if that doesnt work then resort to w2w.
Ted
Compustar Expert
