negative when running
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=130322
Printed Date: February 18, 2026 at 1:48 AM
Topic: negative when running
Posted By: scottyt84
Subject: negative when running
Date Posted: January 21, 2012 at 12:47 PM
I have an Omega Excalibur AL-2000-E with the IB-F3 and connot figure out where to hook up the "negative when running" wire from the IB-F3. If it helps it is on a 2006 Mazda5. Thanks guys!!
Posted By: jstruckman
Date Posted: January 21, 2012 at 1:12 PM
the AL2000-E will have a ground while running output that goes to the ground while running input on the IB-F3.
Date Posted: January 21, 2012 at 1:36 PM
I've got the manuals here in front of me and I don't see it, what wire color is it by chance?
Date Posted: January 21, 2012 at 2:21 PM
well after looking at the manual either, I dont see a ground when running wire either(which I find strange). You could use the ignition ouptut on the satelllite relay remote port and use a relay to make it a negative signal. this will give a negative output while the remote start is running. -------------
Date Posted: January 21, 2012 at 2:31 PM
Look at page 29, a=the diagram at the very bottom, looks like I could use the negative igition or negative start off the red port or the negative ignition on the blue port couldn't I?
Date Posted: January 21, 2012 at 3:05 PM
You would want to use a neg. ignition, not starter. Starter only engaged during crank. the bypass has to see a negative trigger before the remote start attempts to crank. i just looked at the wire diagram, I didnt actually look through the whole manual. So if there is a neg. output ignition then you could use this and not need a relay.
Date Posted: January 21, 2012 at 3:21 PM
I will give that a try, if not I got about 100 relays laying around, I will go that route instead. Thanks for the help!
Posted By: mustyk@att.net
Date Posted: January 24, 2012 at 10:34 PM
Red Satellite relay port blue wire
------------- thetopinstaller
Date Posted: January 25, 2012 at 4:19 PM
thank you sir
Date Posted: January 25, 2012 at 10:07 PM
No Prob
