04 acura tsx, remote start issue
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=130330
Printed Date: April 07, 2026 at 4:14 PM
Topic: 04 acura tsx, remote start issue
Posted By: gyang401
Subject: 04 acura tsx, remote start issue
Date Posted: January 22, 2012 at 12:42 AM
hey hows it going, i recently had a remote start install on my 2004 acura tsx with the use of my factory remote key fob with the xpresskit PKH34 bypass, by pressing lock, unlock, lock *vehicle starts right up*..(WORKS GREAT) but the installer also gave me a remote keyfob with 2 buttons, "start" & "stop" (which i believe was included with the R/S kit), now with that remote, im able to shut off my car once started by pressing STOP on the aftermarket keyfob, and weird thing is i could start up my car with that keyfob, but the factory alarm will trigger and sound, how would i go about to get the aftermarket remote keyfob to start up my car and not sound the alarm....!
my guess is, the guy that install the RS, only activated the bypass by using my factory key fob to lock, unlock, and lock, which would trigger a + signal and activate the module to bypass my factory alarm, and did not bother connecting it with the aftermarket remote start when press to start up the car.
here is my remote start kit installation manual:
https://www.alertautomotive.com/bg/icon_pdf.gif
and here my xpresskit PKH34 bypass module:
https://www.bypasskit.com/Manuals/698_PKH34_H01_S01_D01_I_EN.pdf
let me know if anyone can give me a hand thanks.
Posted By: metz35
Date Posted: January 22, 2012 at 6:25 AM
When you do lock unlock lock , it starts with out setting alarm off because there isn't enough time for the factory alarm to set it self .
It goes of with the fob because he didn't hook up factory alarm disarm wire. Hook it up and you will be good to go.
Posted By: gyang401
Date Posted: January 22, 2012 at 1:00 PM
Okay...are u talking about wiring up the data wire....?
Posted By: metz35
Date Posted: January 22, 2012 at 1:23 PM
No. Pkh34 doesn't do factory alarm disarm. It only does the key bypass
BLACK/ red is factory alarm disarm. In drivers door
Posted By: gyang401
Date Posted: January 22, 2012 at 2:41 PM
alright i think i know what to do now....but just to confirm on the factory disarm wire....BLACK/ red is the disarm wire you said...?...but on this diagram "HERE" it says the disarm wire is (WHITE) if you could confirm this then ill go ahead and wire the white wire.
Posted By: metz35
Date Posted: January 22, 2012 at 2:53 PM
My info says BLACK/ red to white. So it's more than likely BLACK/ red at cylinder and changes to white at the lock and unlock switches. So depending where you connect at depends on the color. I dunno why they do it but when you install as long as I have you see a bunch of stupid stuff haha
Posted By: gyang401
Date Posted: January 22, 2012 at 3:34 PM
I didn't quit understand what u said at the last couple of word...." I dunno why they do it but when you install as long as I have you see a bunch of stupid stuff haha...?
Posted By: metz35
Date Posted: January 22, 2012 at 4:18 PM
It's not important
