remote start in 2003 f150
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=130420
Printed Date: May 15, 2026 at 4:01 PM
Topic: remote start in 2003 f150
Posted By: thor5057
Subject: remote start in 2003 f150
Date Posted: January 28, 2012 at 10:28 PM
I recently installed a code alarm ca6551 in my 2003 f150 supercrew and everything works except the climate control does not come on when i use the remote start.
Posted By: chev104275
Date Posted: January 28, 2012 at 10:36 PM
You missed powering up a wire did you power all of the wires listed ? I just did my truck the other day just bought the same one
IGNITION 1 DARK BLUE/LIGHT GREEN (+) @ IGNITION SWITCH HARNESS
IGNITION 2 RED / BLACK (+) @ IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 1 GRAY / YELLOW (+) @ IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2 BLACK/ LIGHT GREEN (+) @
Posted By: thor5057
Date Posted: January 28, 2012 at 10:51 PM
I may have. thanks for the quick reply. i'll check it. and again thank you.
Posted By: jstruckman
Date Posted: January 28, 2012 at 11:10 PM
yep, sounds like gray / YELLOW is not connected to accessory from R/S. Just did this truck today.
Posted By: thor5057
Date Posted: January 30, 2012 at 12:58 AM
That's what it was thank you both very much. I could have saved timed by having it installed, but I like to do this myself. You can't know too much about your own vehicle. But, it is nice to know there is help if needed. Thanks again.
