1988 bronco 2 remote start probs.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=130436
Printed Date: May 15, 2026 at 7:50 AM
Topic: 1988 bronco 2 remote start probs.
Posted By: blackotto
Subject: 1988 bronco 2 remote start probs.
Date Posted: January 30, 2012 at 9:54 AM
88 bronco 2, 2.9l auto.hey guys,searched all over and cant find the answer to my question.i instaled a car starter(compustar 2wam-s) on my sons bronco as per instructions on this site but i cant get the start func. to work.the alarm part works, it will lock and unlock the doors,flash the lights,but when i want to start it, it will beep 3 times then come back with a single flash of the lights meaning it thinks the car is already running.the jumper in the box is cut for auto trans. and i think everything else is hooked properly.does anyone have any ideas?is there an innitial setup that i missed?also i read somthing about tach learn,does that apply to this setup?any and all help much appreciated.
Posted By: tedmond
Date Posted: January 30, 2012 at 11:42 AM
you have not learned tach. one flash is tach program error for first startup.
connect yellow/black to the tach wire on the car.
start the car, step and hold the foot brake, press and hold start on the remote. the parking lights flash once. release foot brake and take the key out. try remote starting.
------------- Ted
Compustar Expert
Date Posted: February 10, 2012 at 9:51 AM
thank you very much tedmond..going to try rite now
Posted By: tedmond
Date Posted: February 10, 2012 at 10:55 AM
hope that works out, if not watch the parkinglights. they usually indicate the start error.
------------- Ted
Compustar Expert
Date Posted: February 10, 2012 at 12:53 PM
TEDMOND!!! i freekin love you man! everything works absolutly perfect.i kinda knew it was as simple as that but after much much reading no one ever put it simple and straitforward like you. thank you so much,if you were close i would bye you some beer and give you a hug  peace bro.
Date Posted: February 10, 2012 at 12:59 PM
err BUY you some beer....good speeling otto
