auto mate remote start issue
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=130493
Printed Date: May 14, 2026 at 2:12 AM
Topic: auto mate remote start issue
Posted By: sj701
Subject: auto mate remote start issue
Date Posted: February 03, 2012 at 12:01 AM
My wifes car has an Auto Mate remote start system that has worked fine for the past 5 years.  In the last few days the car has been starting itself and running without anyone using the FOB's to iniate a remote start event.  What issue could be causing this?  Bad connection. Battery issue.  Looking for suggestions here.  The place that installed the system is no longer around.
Posted By: Mike M2
Date Posted: February 03, 2012 at 6:19 AM
If both top buttons get pressed it will enter turbo mode, which will make the car start every 3 hours. This will cancel when you start the car with the key or after 18 hours tho...
Mike M2
Tech Manager
CS Dealer Services
Posted By: itsyuk
Date Posted: February 05, 2012 at 12:17 AM
which model so you have?
the main harness on these has a wire that is white w/blue tracer. it is many times hooked to a momentary button mounted to the dash or whatever...that when pressed turns the remote start on or off.
if your system has one of these buttons(and its the black one with the black base),  and you use it frequently, there is an extremely small chance that  the spring is a little weak or some how the button is getting shorted. maybe a newly added tension to the harness like a recent repair under the dash or something.
OR.... that wire wether or not its hooked to a switch is getting shorted briefly and starting the car.
OR ....another scenario is a wore out button on your fob. take the battery out for about a week and see if the problem goes away. first try it with one fob, then the other.
and last thing i can think of...a power loss and restoration to the module with the hood closed can trigger a start too on some models. so maybe look an intermittient power connection
yuk
quiet rural missouri, near KC.
If your system moves you physically and not emotionally, you have wasted your money.
Posted By: KPierson
Date Posted: February 05, 2012 at 12:07 PM
Check the fuse holder in line with the power wire. Many DEI remote starts, for some reason, will sometimes start up if power is cycled. This can be caused by a corroded or damaged fuse holder.
Kevin Pierson
