2002 intrepid, code p1604
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=130534
Printed Date: May 14, 2026 at 12:09 AM
Topic: 2002 intrepid, code p1604
Posted By: angusyoung
Subject: 2002 intrepid, code p1604
Date Posted: February 06, 2012 at 8:48 PM
most likely caused by feed back in park light hook up, what is the proper way to hook up the park lights, using pro start ct3200 and i datalink.
------------- angusyoung
Date Posted: February 06, 2012 at 8:49 PM
newbie here, 2002 intrepid
Posted By: tedmond
Date Posted: February 06, 2012 at 9:37 PM
parking light BLACK / YELLOW (+) DKP
or
parking light YELLOW (-) 110ohm Headlight switch.
use one or the other.
------------- Ted
Compustar Expert
Date Posted: February 06, 2012 at 10:03 PM
thanks tedmond, i am hooked up to the park lights @ blk / YELLOW at drivers front park light, grounded to dash solid ground frame, tried two diffrent rs modules to bp modules, had pcm flashed, and keep getting code p1604 only during remote start.have two accesory wires hooked up, using the 5th relay wire to power the heater motor. at my wits end as to why im getting this p1604 code. voltage drop at ground 0.0 if code is cleared and only use factory key, check engine light will not come on. tach signal is from bypass module to rs module, hardwire mode. code only sets once every 15 or so starts. all solder joints are mirror like. all connectors disconnected from modules before soldering. grounds have been clean and tightened. at my wits ends. ------------- angusyoung
Posted By: tedmond
Date Posted: February 06, 2012 at 10:53 PM
you missed an ignition wire.
use a relay
85 - ignition (-) output from unit
86 -constant 12v
87 - constant 12v
30 - second ign wire
power all wires that you have at the ignition accordingly.
------------- Ted
Compustar Expert
Date Posted: February 09, 2012 at 12:41 AM
Tedmond, thank you, yes i missed the second ignition wire, all working fine now, thank you very much!!!!!!!!!!
