door pop solenoid
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=130638
Printed Date: May 15, 2026 at 8:55 PM
Topic: door pop solenoid
Posted By: 04nata
Subject: door pop solenoid
Date Posted: February 16, 2012 at 9:41 AM
What is the minimum lbs. rating of pull that will get the job done for a small import car?
I see 11lbs - 15lbs - 35lbs all the way up to 100lbs and piced accordingly, so I don't want to spend more than I have to, but I also want it to work. ------------- 2004 Hyundai Sonata
Kenwood KDC-X599 HU
2-Sundown X-18D4
2-SQ Q4500.1
2-SQ Q90.4
1-Massive DBX4
8-Niche 5.25 mids
8-Niche Tweeters
4-Skar 8" mid-bass
OhioGen 220a alt
OhioGen 350a alt
156.0
Posted By: metz35
Date Posted: February 16, 2012 at 11:02 AM
Most foreign cars you can get away with light weight solenoids .
If you want an exact weight.
Use a fish scale attach to door handle and pull. See how many pounds it takes and buy accordingly . Bumping a few pounds to take in age-ing cold weather ect...
Posted By: 04nata
Date Posted: February 16, 2012 at 11:14 AM
I will do the fish scale test, (great idea) ------------- 2004 Hyundai Sonata
Kenwood KDC-X599 HU
2-Sundown X-18D4
2-SQ Q4500.1
2-SQ Q90.4
1-Massive DBX4
8-Niche 5.25 mids
8-Niche Tweeters
4-Skar 8" mid-bass
OhioGen 220a alt
OhioGen 350a alt
156.0
Posted By: 04nata
Date Posted: February 21, 2012 at 11:54 AM
so I got the 40lb solenoid, and my alarm has a negative output channel availiable, do I need a relay or do I wire the positive from the solenoid to constant 12 volts (when key is off) and then just attach the negative from the solenoid to the negative output on the alarm?
I was getting really confused looking therough the relay wiring database, so if I do need a relay will you please point me or post here, how I need to wire it. ------------- 2004 Hyundai Sonata
Kenwood KDC-X599 HU
2-Sundown X-18D4
2-SQ Q4500.1
2-SQ Q90.4
1-Massive DBX4
8-Niche 5.25 mids
8-Niche Tweeters
4-Skar 8" mid-bass
OhioGen 220a alt
OhioGen 350a alt
156.0
Posted By: tedmond
Date Posted: February 21, 2012 at 1:21 PM
i wire them as black to ground, red will be triggered by a relay
85 - ground output from alarm (example aux1)
86 - constant 12v
87 - constant 12v
30 - to positive wire on solenoid.
------------- Ted
Compustar Expert
Posted By: 04nata
Date Posted: February 21, 2012 at 1:44 PM
can those 2 positive's (86 & 87) be the same wire just jumped?
and should that go straight to the battery since it came with a 35amp fuse? or I could run it back to my amps. ------------- 2004 Hyundai Sonata
Kenwood KDC-X599 HU
2-Sundown X-18D4
2-SQ Q4500.1
2-SQ Q90.4
1-Massive DBX4
8-Niche 5.25 mids
8-Niche Tweeters
4-Skar 8" mid-bass
OhioGen 220a alt
OhioGen 350a alt
156.0
Posted By: metz35
Date Posted: February 21, 2012 at 1:46 PM
They can be jumped 86 just powers the relay.
Go to the battery
Posted By: 04nata
Date Posted: February 21, 2012 at 1:53 PM
awesome, thanx for the quick responses !
Kenwood KDC-X599 HU
2-Sundown X-18D4
2-SQ Q4500.1
2-SQ Q90.4
1-Massive DBX4
8-Niche 5.25 mids
8-Niche Tweeters
4-Skar 8" mid-bass
OhioGen 220a alt
OhioGen 350a alt
156.0
Posted By: 04nata
Date Posted: February 24, 2012 at 4:20 PM
So I got it all wired up and working, but only like every 3rd try that it pops. I put a door popper spring on. Could that be an issue? Cuz without the spring it only kicked out part way and was still latched. I also read somewhere that I may be supposed to have a diode on the relay to prevent spikes?
also, your description of the relay hookup varies slightly from what I did find tonite on the site, I assume that both will do the same with the same current and effect?
Kenwood KDC-X599 HU
2-Sundown X-18D4
2-SQ Q4500.1
2-SQ Q90.4
1-Massive DBX4
8-Niche 5.25 mids
8-Niche Tweeters
4-Skar 8" mid-bass
OhioGen 220a alt
OhioGen 350a alt
156.0
Posted By: 04nata
Date Posted: February 25, 2012 at 8:04 PM
anybody ? ------------- 2004 Hyundai Sonata
Kenwood KDC-X599 HU
2-Sundown X-18D4
2-SQ Q4500.1
2-SQ Q90.4
1-Massive DBX4
8-Niche 5.25 mids
8-Niche Tweeters
4-Skar 8" mid-bass
OhioGen 220a alt
OhioGen 350a alt
156.0
