viper alarm, factory horn still honks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=130652
Printed Date: May 16, 2026 at 1:49 AM
Topic: viper alarm, factory horn still honks
Posted By: xiggy4ever
Subject: viper alarm, factory horn still honks
Date Posted: February 17, 2012 at 5:49 PM
I have a viper alarm installed with the voice module that says "Viper Armed" and "protected by viper stand back", problem is when the Viper Security System responds to a triggered threat or simply arming the system the horn honks as well and it is drowning out the Viper security systems siren... where can i find the trigger wire of a relay somewhere so that the horn does not honk upon arming the security system?
It's installed on a 2005 Dodge Dakota SLT quad cab
Any help would be greatly appreciated!
Posted By: Mike M2
Date Posted: February 17, 2012 at 10:03 PM
You don't mention what bypass you are using so we can only guess. Some work off the data of the factory keyless entry, so if the honks are turned on when you use the factory remote they will when you use the aftermarket. Most Chrysler products are prgrammable for the factory honks, look in the Dodge owners manual for info on turning them off....
Mike M2
Tech Manager
CS Dealer Services
Date Posted: February 18, 2012 at 7:11 PM
jeepers,
Answer was in the manual!
i was way over thinking this entire process!, Many Thx mate!
