compustar and dball, 2007 jeep wrangler
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=130760
Printed Date: April 06, 2026 at 3:54 AM
Topic: compustar and dball, 2007 jeep wrangler
Posted By: mcove
Subject: compustar and dball, 2007 jeep wrangler
Date Posted: February 28, 2012 at 7:59 PM
I installed a compustar cm6000as and a dball on a 2007 jeep wrangler with a manual tranny. after install was complete and 1 channel remotes were programmed I tested it. All worked in reservation mode, jeep stayed running ,closed doors and jeep shut down and locked. When I tried to remote start it lights flashed, ignition turned on but started never kicked in.Double checked everything and quit for a couple of days. when I tried to test it again I could not get reservation mode to work, jeep would not stay running. help
Posted By: mcove
Date Posted: February 28, 2012 at 8:00 PM
2007 jeep wrangler manual tranny
Posted By: tedmond
Date Posted: February 28, 2012 at 8:27 PM
how many parking light flashes?
1) reprogram tach
2) did you bypass the clutch correctly
3) try to remote start with the system disarmed. If it starts with the system disarmed, you have your starter kill installed "reversed"
Ted
Compustar Expert
