Viper 800esp Honda 2001 Civic
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=13106
Printed Date: April 19, 2026 at 2:22 AM
Topic: Viper 800esp Honda 2001 Civic
Posted By: nannerb
Subject: Viper 800esp Honda 2001 Civic
Date Posted: May 03, 2003 at 12:14 PM
I am looking into putting a Viper 800esp into my 2001 Honda Civic sedan myself.  However wiring the door locks is starting to worry me.  Am I able to wire the door locks from the brain of the viper to the keyless entry harness that is already in my car and if so would that make it any easier than wiring the brain directly to the locks?  Thanks
Posted By: draasch
Date Posted: May 04, 2003 at 8:33 AM
your door locks are a neg system. very to do...
Constant 12 volts WHITE IGNITION SWITCH HARNESS
Ignition 12 volts BLACK / YELLOW IGNITION SWITCH HARNESS
Starter BLACK/ WHITE BACK OF DRIVER FUSE BOX *
Dome Light GREEN/ RED (-) AT UNDER DASH FUSE/RELAY BOX **
Trunk Pin Switch RED (-) AT SWITCH OR LIGHT IN TRUNK
Parking Lamp RED / YELLOW (+) AT UNDER DASH FUSE/RELAY BOX ***
Power Lock WHITE/ BLUE AT 20 PIN CONNECTOR IN #201
Power Unlock WHITE/ GREEN DRIVERS KICK PANEL
#201-See Negative Pulse Door Lock Diagram. * Installing A Starter Kill Relay At The Ignition Switch Harness Before The Starter Wire Enters The Driver Side Fuse Block May Cause A "Check Engine" Light To Come On. Starter Wire Should Be Accessed After Fuse Block.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
