viper remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=131283
Printed Date: April 11, 2026 at 6:28 PM
Topic: viper remote start
Posted By: rock861261
Subject: viper remote start
Date Posted: April 26, 2012 at 2:55 PM
I have a viper 5701 and i can get my car remote started however I cant get the starter to disengage. I have a ls1 camaro.
I tried all 4 (tach, virtual tach, voltage and none) and it still keeps running
My crank time is .6
And I currently have my tach wire going to r10 on the pcm.
Posted By: smokeman1
Date Posted: April 26, 2012 at 8:25 PM
What year is the car?
Is it possible you have a ignition wire from the 5701 connected to the starter wire?
What wires from the 5701 are connected to the car?
Date Posted: April 27, 2012 at 12:05 AM
Its a 91 camaro trans plant. I know the starter wires are correct. I have a green and a purple
Posted By: howie ll
Date Posted: April 27, 2012 at 6:09 AM
1) Did you actually program and set the tach?
2) Do you have the starter cut correct? Green to key side and violet to starter side?
a) Test the violet under R/S conditions to make sure it cuts out in under a second.
b) Reconnect the starter and just join the violet, see what happens
