spal 37000118 door lock switch
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=131373
Printed Date: April 07, 2026 at 7:40 AM
Topic: spal 37000118 door lock switch
Posted By: sgarcia1212
Subject: spal 37000118 door lock switch
Date Posted: May 07, 2012 at 3:33 PM
hi all,
does anyone have a wiring diagram for the spal 37000118?
I'm adding this switch to aftermarket actuators.
additional info:
Truck-99 Tacoma
Alarm-Python 533
I'm using a relay pack DEI 451m.
Thanks in advance.
posted_image
SGARCIA1212
Date Posted: May 07, 2012 at 3:39 PM
Edit for my previous post:
here is the link for the switch that I want to install.
https://www.spalusa.com/store/main.aspx?p=itemdetail&item=37000118
thanks.
SGARCIA1212
Posted By: howie ll
Date Posted: May 07, 2012 at 5:29 PM
Here's an experience based test.
Go to the reference data and look at the reverse view.
Top right is illumination
Middle three are obvious, 2 x grounds and 12V+.
Bottom two will be your motor wires.
To find out, with a meter set to continuity buzzer or low ohms, and the switch at rest both of the lower two should be continuous with the pins marked ground.
Move the switch one way and one stays continuous with ground the other becomes continuous with the +.
Move in the other direction and those connections are reversed.
Date Posted: May 08, 2012 at 9:47 AM
Thanks howie ll.
I've learned so much from all your replays to different people.
Thanks for sharing you knowledge.
SGARCIA1212
Date Posted: May 08, 2012 at 11:48 AM
one more question howie ll,
is necessary to add installing an after marker door lock switch?
posted_image
Thanks in advance.
SGARCIA1212
Date Posted: May 08, 2012 at 11:52 AM
Edit my above post:
question was, if is necessary to add Diodes when adding a door lock switch.
SGARCIA1212
Posted By: howie ll
Date Posted: May 08, 2012 at 8:33 PM
No it won't work you need a 5 wire actuator and a dedicated timer relay from Spal, Mes etc. And all the wiring will be different.
Date Posted: May 08, 2012 at 8:45 PM
Ok.
Thanks.
SGARCIA1212
