accord immobiizer disable
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=131383
Printed Date: April 07, 2026 at 2:56 AM
Topic: accord immobiizer disable
Posted By: tlkolrod
Subject: accord immobiizer disable
Date Posted: May 09, 2012 at 10:31 PM
Hello I am having issues with my daughters 99Honda Accord . Some times it starts  sometimes it does not. The Green Immobilizer key light comes on and blinks 5 times then goes off. This happens even if the vehicle does start. I would like to dis arm the system or bypass the system. Can the ecu be adjusted to enable starting without  using the immobilizer circuit ? We have had a new key made at the dealer but that did not solve the issue. There is no remote start system on the car. It is bone stock
Thanks Toby
Posted By: kreg357
Date Posted: May 10, 2012 at 7:38 AM
PM sent....
Posted By: howie ll
Date Posted: May 10, 2012 at 11:18 AM
No it can't be removed from the system, if you have intermittent problems a different key (chip)won't cure it, better to have spent the money on the dealer's diagnostics.
I'm betting on a bad connection with an ignition circuit somewhere,
as a last resort have the chip removed from the key and glued to the antenna ring around the key.
Warning no-anti theft and possibly insurance implications if they find out.
Posted By: i am an idiot
Date Posted: May 10, 2012 at 2:38 PM
I have replaced a chip inside the ECU in a Honda. The customer got it and brought it to me, I have no idea where he got the part. Since it was taken private, I am sure kreg knows where to get said part.
Posted By: tommy...
Date Posted: May 10, 2012 at 2:51 PM
Kreg probably helped in the PM... Just a side-thought... Could a R/S have been installed previously? Maybe removed... No remotes... Sometimes the connections points are exposed... or poorly insulated.
M.E.C.P & First-Class
Date Posted: May 10, 2012 at 7:44 PM
Posted By: tlkolrod
Date Posted: May 11, 2012 at 5:02 AM
The Accord never had a R/S   It was my Aunts  (93) from new    I was hoping one of you young fellas doing swaps would have figured out how to eliminate the entire immobilizer loop.  I want to just get in and stick in a regular key and not worry about any transponder Bull.   I visited the web page above and we are getting close. However that still uses some form of identification.  I will keep looking.  Thanks for the ideas so far. Keep them coming
Toby
Posted By: howie ll
Date Posted: May 11, 2012 at 5:15 AM
OP, your first post said 99 and your last 93.
Could you please make up your mind what year this Accord is or at least check your posts.
AFAIK 93 US spec Accords never had factory immobilisers.
Posted By: kreg357
Date Posted: May 11, 2012 at 5:21 AM
Another possibility :  The Accord is a '99, the Aunt is 93 ( years old ) ???   posted_image
Posted By: tlkolrod
Date Posted: May 11, 2012 at 5:25 AM
I have made up my mind and I do check my post before I send. The car is a 99. The aunt (Evlyn) was 93. Sorry if I misled you. She has passed on and sold us the car. She never had a R/S in place.
Posted By: tlkolrod
Date Posted: May 11, 2012 at 5:27 AM
Thank you Kreg
Posted By: howie ll
Date Posted: May 11, 2012 at 5:35 AM
And 2 from me, sorry if I sounded bit harsh.
My earlier comments still apply though about diagnostics, we don't know whether it's the chip or the immobiliser itself.
Though I believe Mr. I is on the right track..
Date Posted: May 11, 2012 at 8:09 AM
i am an idiot wrote:
https://www.doctronic.at/Mobilizier_Board_E.htm
That is the only way I know of to bypass it completely.
