python 1401 mts problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=131400
Printed Date: April 06, 2026 at 2:42 PM
Topic: python 1401 mts problem
Posted By: wblakes
Subject: python 1401 mts problem
Date Posted: May 13, 2012 at 10:50 PM
i finished installing the Python 1401 into an 04 Honda Accord Manual and i cannot engage MTS. i did the MTS procedure and i do not get the five flashes for engagement. i put it in Automatic Mode and it works fine. i tested the foot brake and e-brake wires and they all work. am i missing something?
Posted By: dasbogie
Date Posted: May 14, 2012 at 12:04 PM
for manual mode you Must run a tachwire and program it first.  Did you complete those steps?  Did it learn successfully?   Also, did you get a door trigger wire?
Advanced
Posted By: wblakes
Date Posted: May 14, 2012 at 7:52 PM
Yes i did run a Tach wire and also a door pin wire. I installed remote start on manual cars before without any problem
