autopage c3 rs665 2w cant get to work
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=131497
Printed Date: April 06, 2026 at 6:35 PM
Topic: autopage c3 rs665 2w cant get to work
Posted By: nakok
Subject: autopage c3 rs665 2w cant get to work
Date Posted: May 28, 2012 at 1:59 PM
C3-RS-665-2W is for 2010 RAV4 not a smart key but equiped with OEM keyless. all i want is locks and auto start. all 3 input powers wired from big white at fuse box. Violet>big yellow and small white at switch. Pink>small pink at switch. Yellow>good size white at switch.Brown>small red at switch. H7 pin12 pink>blue at tumbler. H7 pin3 WHITE/ violet>brake depressed power. did not wire hood pin. H2 black wire going to OEM left kick panel connector ground. should this atleast be at run possition even if i wired the bypass module wrong with start button pressed? i checked the connections afews time, i even pulled on it. just reminder the unit went through the programming mode ok except feature D at STARTING & ADJUSTMENT step.any help would appreciate.
Posted By: jstruckman
Date Posted: June 03, 2012 at 10:01 AM
Did you ground the neutral safety switch wire on the 665. should be a BLACK/ white wire.
