2 remote starters one fob
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=131901
Printed Date: May 03, 2026 at 10:24 AM
Topic: 2 remote starters one fob
Posted By: log2
Subject: 2 remote starters one fob
Date Posted: July 29, 2012 at 4:50 PM
So I have 2 remote starters, one of which is for standard transmissions only (Prostart 3360) and the other is for automatic transmissions (Prostart 3200)
The PS 3200 doesn't have remote door unlock, or remote trunk pop, all it has is remote start, where the PS 3360 has remote door lock, and trunk pop, but as stated is only for standard transmissions. Is it possible to program both of them to the same key fob? So I can have all the features?
Posted By: 91stt
Date Posted: August 23, 2012 at 10:40 PM
you can use the 3360 in an automatic transmission equipped vehicle. you will just need to go through the ready mode procedure every time you want to use the remote start.
This information is provided only as a reference.
All circuits should be verified with a digital multi-meter prior to making any connections.
