2003 chrysler town country parking lights
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=131956
Printed Date: May 01, 2026 at 10:01 PM
Topic: 2003 chrysler town country parking lights
Posted By: usmcvet
Subject: 2003 chrysler town country parking lights
Date Posted: August 05, 2012 at 1:37 PM
Installing a R/S on a 2003 Chrysler T & C and it says the parking light wire is a NEGATIVE BROWN / white at the switch,but there is no WHITE/ brown or BROWN / white at the back of the parking light switch. R/S works fine but having problems finding the parking light wire. Thanks !
Posted By: howie ll
Date Posted: August 05, 2012 at 3:15 PM
Go to the Downloads/Manuals section above, in the right hand search bar, enter DEI 1082.
It's more complicated than you think, requires a relay and a resistor.
Posted By: usmcvet
Date Posted: August 05, 2012 at 3:30 PM
Ok,Thanks ! On the relay # 87 is to the resistor,just wire both ends of the resistor together and wire to # 87 on the relay ? Thanks !
Posted By: usmcvet
Date Posted: August 05, 2012 at 3:39 PM
I see now about the resistor,one ends goes to ground. On the # 30 on the relay it says it goes to lights. What lights ?
Posted By: kreg357
Date Posted: August 05, 2012 at 4:07 PM
At the light switch connector there is a WHITE/ Brown wire ( MUX wire ). You cut that wire and connect the correct ends to the relay pins shown. You are isolating the switch when the R/S outputs its' Parking Light signal and applying the 2.1 k ohm resistor to the vehicles MUX circuit to turn on the Parking Lights.
------------- Soldering is fun!
Posted By: enice
Date Posted: August 06, 2012 at 10:41 AM
Just get a WHITE/ orange(+) wire at the driver's kick panel. No need for a relay or resistor.
Posted By: howie ll
Date Posted: August 06, 2012 at 10:46 AM
Ta Eric, I've only ever done Audio, Bluetooth and tracking, heck it's called a Chrysler Voyager here and built in Austria!
