aftermarket centrallock module alternate?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=131982
Printed Date: April 30, 2026 at 10:43 PM
Topic: aftermarket centrallock module alternate?
Posted By: gsus
Subject: aftermarket centrallock module alternate?
Date Posted: August 09, 2012 at 2:17 PM
I'm putting a complete system in my dads car (a 99 wrangler). I already had a 5wire (driver side door) actuator and two 2wire actuators (passenger and rear doors)... however, I can't find the module that came with the kit (bought it long time ago). Do I have any alternatives? I would like my dad to have the ability to lock and unlock all doors from his chair.
Is this something I can make work myself with additional relays (I already have a 451m to wire them all as 2wire actuators, just in case)?
For the record, I've searched online to try and find just a module without actuators... but no luck :(
Posted By: smokeman1
Date Posted: August 09, 2012 at 4:49 PM
Try E-Bay for keyless entry systems.
------------- When all else fails, Read the Instructions
Posted By: howie ll
Date Posted: August 10, 2012 at 1:31 AM
If you use a 451 the 5 wire is redundant.
If you want to use the 5 wire, either via a momentary (window) type switch, that's also OK. Simpler and better than a 451.
If you want to use key indoor, then you need a dedicated timer relay, available in the US from Spal or MES, Metra, Scosche etc.
