python 3000, 2012 tacoma
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=131991
Printed Date: April 30, 2026 at 4:16 PM
Topic: python 3000, 2012 tacoma
Posted By: johnman14
Subject: python 3000, 2012 tacoma
Date Posted: August 10, 2012 at 11:59 PM
posted_image
Help! i'm installing a Python 3000 and this is what I have right now and it doesn't work.  I also need to know what to do with,  The (+) ignition (out to alarm),  (-) neutral safety and the anti-grind.  thank you
2012 Toco
Posted By: Mike M2
Date Posted: August 11, 2012 at 9:40 AM
What about the second ignition blue / YELLOW? It needs to get energized from the pink/white. You also need to add a relay for the GREEN/ black starter wire. Do you have an immobilizer bypass?
Mike M2
Tech Manager
CS Dealer Services
Posted By: howie ll
Date Posted: August 12, 2012 at 1:17 PM
Firstly I'm confused, Python 3000 according to Directwire was simply an alarm.posted_image
If I'm wrong you have a wire called "status output" aka GWR this goes to the keysense, diode split if a by-pass is needed.
Neutral safety; go to the base of the handbrake lever, there will be a switch with 1 wire, connect to it.
Yellow ignition + use with the anti-grind relay.
Use satellite relay output (thin purple second starter neg (-) output) for the second starter relay.
You wiring above is all wrong
I've used the correct DEI and Toyota colours.
The only one not listed was the ACC, not really required for R/S anyway.
Your pink/white should be set as ignition 2 (Default).
The relay marked 2 is the anti-grind, orange GWA to 85 and the yellow to 86.
Relay #1 is your second starter relay.
N.B. You have TWO constants at the ignition, one is 50 and one 30 amp fused why on earth would you chose the 30 when each of your wires has a 30 amp fuse?
Split the damn load, 1 to each.
As for tach that shou7ld be pin 9 at the diagnostic socket under driver dash (OBD ll).
