viper 5904
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=132094
Printed Date: May 14, 2026 at 11:25 PM
Topic: viper 5904
Posted By: giantrock
Subject: viper 5904
Date Posted: August 29, 2012 at 10:56 AM
Hi there,
I am planning to install a Viper 5904 alarm security to my car (2009 Mazda 6 V6). Do I need a Relay for the installation (i.e. for trunk realese, doors...etc)?.
Thanks,
Posted By: kreg357
Date Posted: August 29, 2012 at 11:09 AM
Don't think so, at least not for the trunk release. Here is a link to a pictorial on a 2010 ( 2009 - 2011 should be the same).
https://www.the12volt.com/installbay/forum_posts.asp~TID~130129~PN~1 ------------- Soldering is fun!
Date Posted: August 29, 2012 at 1:00 PM
Thanks kreg357 for the quick answer - It is much appreciated.
Posted By: howie ll
Date Posted: August 29, 2012 at 5:10 PM
I'll let you handle this one K. hands across the pond etc.
By the way the reason the 59XXs were never sold in the UK was that allegedly the frequencies were illegal for that form of radio control.
Anyway I'm watching American Guns.
Posted By: howie ll
Date Posted: August 29, 2012 at 5:26 PM
09 and 10 the same according to Directwire.
2 relays for the locks or a 451 module plus 2 x 1N4004 diodes and a 1K resistor.
He won't need parking lights, European, direction indicators. Make the white output wire NEG (-) and connect to BLACK/ orange at the white 30 pin plug (plug 3) pin W at the BCM.
Needs 1097 and or 1021 tech tips for the door triggers, I believe they're in the Downloads/Manuals section here.
Posted By: kreg357
Date Posted: August 29, 2012 at 6:26 PM
Or use a Fortin EVO-ALL. Does transponder, locks & alarm and supplies door, trunk, brake & ebrake status plus a tach signal. All for around $60.
Date Posted: August 30, 2012 at 3:06 AM
Thanks guys. just to clarify one thing here that is the car is US Model (Mazda 6 3.7L V6), I bought is from USA in 2009. so do I still need to use relays even if it is US model?. Thanks
Posted By: howie ll
Date Posted: August 30, 2012 at 3:50 AM
Yes but K's suggestion of using the Fortin by-pass is spot on, either from Fortin in Canada or via Armour Auto UK...actually I have a trading account with them, it's a new product range for them I doubt whether anyone but R/S specialists like myself would carry the product though.
Are you with US Forces, Lakenheath air base etc.?
I've done work there before.
Date Posted: August 30, 2012 at 7:37 AM
Thanks howie II and kreg357. I forget to mention that I also bought the Xpresskit DB-ALL bypass module. Will that work as Fortin EVO-ALL or I still need to use relays with it?.
No I work in Oil industry!...
Posted By: howie ll
Date Posted: August 30, 2012 at 7:46 AM
Sorry, my brother-in-law worked for Texaco in lubricants for many years, spent lots of time in far away places, I think he preferred San Francisco to Siberia.
It's just that you appear to be on a long time assignment.
You'll just have to get used to the gasoline prices over here.
Not sure, Fortin definitely more reliable, Kregg has the answers.
Posted By: kreg357
Date Posted: August 30, 2012 at 8:11 AM
The DB-ALL is a full featured bypass module like the EVO-ALL. The DB-ALL must be flashed with the correct firmware ( 401.Mazda V1.10.11 currently, V1.10.14 is beta ).
It will do the door locks without relays. Follow the Type 5 diagram in the DB-ALL install guide. ( Very confusing guide. The chart says it does the trunk release but there is no W2W wire shown in the diagram, same for window up / down. Gotta love DEI......) ------------- Soldering is fun!
Posted By: howie ll
Date Posted: August 30, 2012 at 8:28 AM
What? A mistake, typo or unclear instructions with a DEI product....  ------------- Amateurs assume, don't test and have problems; pros test first. I am not a free install service.
Date Posted: August 30, 2012 at 8:33 AM
Thanks kreg357. Yes I also bought the XKloader2 to flash the DB-ALL to correct 2009 Mazda 6 firmware.
Thanks guys for the help. I think I am now good to go with the installation..............
Date Posted: September 03, 2012 at 3:46 AM
Hi guys,
One more question  ?. I am trying to use DB-ALL with D2D option. Do I need to connect any wires from the 4 pin harness on the right bottom corner (see the install guide link - https://www.xpresskit.com/VehicleCompatibility.aspx?src=vs1&p=null&year=2009&make=Mazda&model=6&ps=1&s=0&c=0, which has (+) 12V, RX, (-)Ground, and TX. It doesn't look like I need to from the install guide, I just need to confirm.
Thanks,
Posted By: kreg357
Date Posted: September 03, 2012 at 5:56 AM
As noted above, the DB-ALL install guide is confusing.
In W2W mode that port would not be used. In D2D mode, that port will be used for the D2D harness that goes to the Viper's D2D port. It provides a communication path between the Viper and the DB-ALL to perform all the functions of the dashed blue wires on the install diagram. Notice in the module programming guide, Page 9, Step 2a lists that D2D harness to be plugged in last.
The D2D harness should have been included with the DB-ALL. ------------- Soldering is fun!
Date Posted: September 03, 2012 at 6:23 AM
Thanks kreg357, Yes it is confusing, I think they do it on purpose so we keep do the installs at their garages!
Posted By: kreg357
Date Posted: September 03, 2012 at 6:39 AM
Exactly ------------- Soldering is fun!
