controling heated seats with compustar
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=132232
Printed Date: May 15, 2026 at 10:39 AM
Topic: controling heated seats with compustar
Posted By: boeingone
Subject: controling heated seats with compustar
Date Posted: September 20, 2012 at 4:13 PM
I have a 2010 Ford Edge with a Compustar cm6000. I would like to control the heated seats.
Can someone tell me the best way to do this?
I also have the OP500 programmer.
I the can program it to turn the seats on below 32 deg.
I checked the wire that controls the seat and it has battery voltage until you press the heated seat switch then it momentarily drops to .125 volts the back to battery voltage.
Thanks,
Posted By: howie ll
Date Posted: September 20, 2012 at 4:45 PM
Try grounding that wire for about 1 sec.
The worst you can do is to blow a fuse.
Date Posted: September 21, 2012 at 8:46 AM
Ok will give it a try this weekend.
Would it help if I post the wiring diagrams?
Thx
R
Posted By: offroadzj
Date Posted: September 21, 2012 at 9:01 AM
Actual wiring diagrams of the heated seats circuit or just wire lists that you can get from DEI / wiremagic / etc? Wire diagrams of the actual circuit would probably help but I have a feeling they are ground pulse activated like Howie said. If you hold the button in, does that wire continue to show ground (voltage drop)? And does it still show ground (voltage drop) when pressing it again to turn the seats off?
------------- Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
