2012 civic wont stay running
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=132343
Printed Date: April 08, 2026 at 4:15 PM
Topic: 2012 civic wont stay running
Posted By: luvlexus101
Subject: 2012 civic wont stay running
Date Posted: October 09, 2012 at 10:55 AM
Hey guys. I just installed a Viper 5704 with the DBALL module using Dd interface. Everything works great but when the car is remote started it only runs for 20-30 seconds and then it shuts off and starts again. It continuously does this. Any ideas?
------------- G Lock
Posted By: kreg357
Date Posted: October 09, 2012 at 11:03 AM
Did you set the Viper to Engine Sensing = Tach Mode ( could happen automatically with newer 570x's ) and do the Tach Learn Process?
------------- Soldering is fun!
Date Posted: October 09, 2012 at 11:10 AM
It was initially on virtual tach and I thought that might be the issue. So I switched it to voltage sense but that doesn't seem to be working either. I'll try the tach sensing procedure in tach mode next. However if I just do no checking setting would that also solve the problem?
Date Posted: October 09, 2012 at 11:15 AM
Ah actually just read the manual again. After so many installs I can't believe I left that step out. Thanks again. I will do that and report back.
Posted By: Mike M2
Date Posted: October 09, 2012 at 7:57 PM
Anything other than a true tach signal in this car(and many new Honda's) will start but only run for less than a minute due to the charging system in them. They are made to not charge at all while at idle to conserve gas, thus always showing a problem sensing voltage(at least this is what Honda says). I remember the first new Civic i did had this same issue and i ran an injector wire in the car for tach. Never had an issue since...
------------- Mike M2
Tech Manager
CS Dealer Services
Posted By: offroadzj
Date Posted: October 09, 2012 at 7:58 PM
That actually makes a lot of sense... something I'll keep in mind for future. Although, I always use tach to be safe.
------------- Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Date Posted: October 16, 2012 at 8:16 PM
Worked fine, the DB-ALL module provided the tach signal and once I learned the signal everything was cake!
Posted By: eez4life
Date Posted: October 28, 2012 at 9:57 PM
Hello.
I had my alarm/remote start installed last year and had the exact problem. The installer couldn't figure it out...here is the info he posted on this site.
"Im still scratching my head, so hopefully somebody has come across this problem in the past.
Vehicle: 2012 Honda Civic Coupe
Remote Starter: Viper 5901
Bypass: Xpresskit DB-ALL (installed D2D)
The bypass programmed right in... Keyless, trunk release, door triggers, factory arm/disarm, and the transponder bypass is fully functional.
When the vehicle is remote started, the lights flash and the vehicle starts. Because I have it set to virtual tach, the lights take 15 seconds to turn on showing that the vehicle is remote started. Once they turn on, the vehicle shuts down after 15 seconds. Shutdown diagnostics says that the brake was pressed.
For doodies and giggles, I turned the parking lights on at the switch, and attempted to remote start the vehicle again. This time it stayed running for the default 12 minutes. I removed the fuse for the lights thinking there was a weird draw or something, but the same issue exists."
I'm not the installer and haven't been able to reach him so I'm hoping someone can walk me through this fix..??? Is it super complicated to fix?? Thanks.
Posted By: eez4life
Date Posted: October 28, 2012 at 10:24 PM
Really stupid question...Will turning off engine checking mode fix this issue??
Posted By: howie ll
Date Posted: October 29, 2012 at 1:55 AM
And yet again. ALWAYS connect to and learn tach.
If you can't find it, older diesel etc. use a tach sensing device, DEI market a very good one.
Posted By: eez4life
Date Posted: October 29, 2012 at 10:48 AM
Hey sorry for the ignorance but I am not an installer and don't have knowledge on this topic. I understand running tach wire is best bet. I guess I should find a reputable shop and have them run the tach wire??? I don't wanna get ripped off and was wondering what that should cost me?? Any answers are much appreciated.
Posted By: soundnsecurity
Date Posted: October 29, 2012 at 10:55 AM
to answer your question, yes, if you turn engine checking off it will likely solve the problem because it wont look for a tach or voltage signal and the engine will stay running. but, the side effect of not using engine checking is that if the car does not start on the first try then it will not try again and it also will not shut the ignition off until the remote start times out which could potentially kill your battery.
Posted By: howie ll
Date Posted: October 29, 2012 at 11:53 AM
Injectors, top of engine cylinder head, any of the following:-
Brown, red, blue or yellow.
Posted By: beegbie
Date Posted: October 29, 2012 at 6:23 PM
Most shops will stay away from a situation like this. Or charge you a premium price. They don't want to "own" your install (get blamed for anything else that goes wrong). It's kinda like taking your half cooked bacon and eggs to Denny's and asking them to finish it off for you. Yup, you would get laughed at.
We could help here though. First you will need to find the brain and find the violet/white wire at the brain and find a way out under the hood. There is a rubber gromet that can be used to the left of where the clutch pedal would go through. Run it to one of the coil wires as listed in previous post, then you will need to program.
