04 escalade astrastart
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=132352
Printed Date: April 08, 2026 at 5:49 AM
Topic: 04 escalade astrastart
Posted By: 2004escalde
Subject: 04 escalade astrastart
Date Posted: October 09, 2012 at 11:50 PM
Got this vehicle and it has 4200 module with idatalink ads-al 32
No remote.
Got a new remote , programmed it, all but starter works.
Vehicle fires up and than dies. Unit flashed 4-times. Tach issue ?
The wiring to the datalink is all as per diagrams.
When i try to autolearn tach signal by flipping switches 1567 and fire it up all warmed up, hit the brake and nothing happens, the led just stays off...
What am I missing, help !
Posted By: offroadzj
Date Posted: October 10, 2012 at 5:53 AM
I don't know the programming for those, but first make sure there is a tach wire connected, second make sure the unit is programmed for tach signal sensing.
Also try remote starting it with the key in the ignition. The bypass may just need to be reprogrammed.
------------- Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Date Posted: October 10, 2012 at 9:39 AM
Hi.
I am using the idatalink , the tach feeds from there, Datalink on escalade only taps into 2 oem wires. One to the obd port and 2nd to ignition.It has solid green on it, so it appears programmed.
Key makes no difference.
Posted By: kreg357
Date Posted: October 10, 2012 at 4:30 PM
Not familiar with the astrastart but...
Does the astrastart 4200 do "PitStop Mode"? If it does, go into PitStop Mode, take out the key and see if it stays running. If it does, depress the Brake Pedal to see if it shuts the engine down. Then you'll know if most everything is connected properly and the Brake Input works. ------------- Soldering is fun!
Posted By: gorfllub
Date Posted: October 15, 2012 at 10:54 AM
I assume you mean AstroStart? Could also be security/bypass problem.
As Kreg says, check and see if it will go into takeover mode / continuous run / pit stop / or whatever you want to call it.
To do this, press the start button while the engine is running with the key. If it continues to run once the key is removed then it's time to look at reprogramming the bypass and checking all its connections.
Also the LED on the brain should flash consistently when the engine is running with the key. This is an indication that it is receiving a tach signal.
Posted By: auto enhancers
Date Posted: October 15, 2012 at 11:02 PM
I have had tach the ads bypasses not wanting to work with some starts. I would recommend running the tach wire from the astrostart up to the white wire at the cluster. Then reprogram tach.
