2005 escape lock wires
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=132551
Printed Date: May 21, 2026 at 11:54 AM
Topic: 2005 escape lock wires
Posted By: lucasoil4u
Subject: 2005 escape lock wires
Date Posted: November 02, 2012 at 11:33 AM
Trying to find the lock wire on an 2005 escape. Says Pink and white. No pink or white wire in the drivers kick or at the GEM module. Thanks
Ryan
Posted By: kreg357
Date Posted: November 02, 2012 at 12:10 PM
The Escape has a one-wire lock system.  The wire you are looking for is Pink wire  with a White stripe.  You can locate it with a DMM set to 20V DC. Connect the
Red test lead to +12V constant and the Black test lead to the suspect wire.  You should see the DM go to +12V with an Unlock command.
Here is some more info from Ready Remote :
Power Lock       pink/white  (-) driver kick or SJB, conn. D, pin 22
Power Unlock    same as power lock wire
Lock is negative trigger thru a 1,000 ohm resistor. Unlock is a straight negative trigger. MUST use relays.
The SJB (Smart Junction Box) is the fuse/relay box on the passenger side of the center console.
Depending on the R/S system you are using, beside the 1k ohm resistor you might need relays or go the easy way and use a DEI 451M module.
Posted By: chev104275
Date Posted: November 02, 2012 at 1:01 PM
I've done these using the pink/white for unlock and there is a WHITE/ violet for lock    straight ground no resistors needed
