2011 dodge ram 3500 diesel
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=132557
Printed Date: May 21, 2026 at 4:08 PM
Topic: 2011 dodge ram 3500 diesel
Posted By: ziggyb222
Subject: 2011 dodge ram 3500 diesel
Date Posted: November 02, 2012 at 7:42 PM
Going to install a Viper 4103 starter in this truck.. 2011 Ram 3500 Diesel. The truck has no power locks and roll up windows. Want to know if the T-harness and what bypass works best for this truck. I have used most of all the brands out their just looking for some more input for this truck...Thanks in Advance!!!!
Posted By: shortcircuit161
Date Posted: November 02, 2012 at 10:23 PM
Either of these 2 modules/harnesses work perfect with that truck.
Fortin EVO-ALL with THAR-CHR4
or
iDatalink ADS-AL CA with ADS-HRN CH4
Alternate iDatalink modules that also work with that harness are -
ADS-ALSL CH or ADS-DLSL CA2
I prefer iDatalink over anything but Fortin is also rock solid.
You will need to connect them W2W since the Avital cannot talk D2D to either of those modules. But W2W is more reliable anyway.
Good Luck!
Date Posted: November 03, 2012 at 12:48 PM
Yes I always do wire to wire and solder everything. I am not a professional installer but have done a lot of starters and rely on this site a lot for advice. Thanks for taking the time to respond to my question... People like you are why this site is so great!!!!!! Thanks!!!!!
Date Posted: November 10, 2012 at 5:00 PM
The ADS-HRN-CH4 shows it is for the Tip Start models... I do not see a harness for the regular Black headed key. Am I missing something???
Posted By: metz35
Date Posted: November 11, 2012 at 5:09 AM
The harness on the back of the key cyclinder is still the same even though you don't have the fancy key.
