03 pathfinder disarm for trunk release
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=132708
Printed Date: May 16, 2026 at 5:02 AM
Topic: 03 pathfinder disarm for trunk release
Posted By: afridihamid
Subject: 03 pathfinder disarm for trunk release
Date Posted: November 18, 2012 at 10:08 PM
2003 Pathfinder Automatic. Double pulse (-) unlock & disarm ( Lt. Green). Single pulse (-) lock & arm (Yellow).
I will be connecting the glass hatch release (using a relay) to the Compustar CM5200.
I would like to avoid the hatch release from setting off the factory alarm. Will the CM5200 send a disarm signal before releasing the hatch?
Another question:
The lock wire on the car also arms, and the unlock wire also disarms...
Is it okay to connect both the lock & arm wires from the RS to the single lock&arm wire on the car (vice versa w/ unlock & disarm)?
If yes, should I use a diode on each ends coming from the RS to isolate the lock from arm, and unlock from disarm?
Posted By: howie ll
Date Posted: November 19, 2012 at 1:50 AM
Don't know.
And yes on the lock arm.
Date Posted: November 19, 2012 at 7:12 AM
Thank you! Just to confirm, no diodes are needed?
Thanks again.
Posted By: howie ll
Date Posted: November 19, 2012 at 7:51 AM
Yes on the lock/arm and unlock/disarm wires.
If you do this you lose auto-lock though.
Posted By: shortcircuit161
Date Posted: November 19, 2012 at 8:02 AM
I just looked thru the install manual of the CM5200 and the info you are looking for is in there with options to change if you wish.
Date Posted: November 19, 2012 at 6:03 PM
Unfortunately the manual I have does not have this option in the programming table.
In my CM6200 manual, it shows this feature in option 1-07.. In the CM5200 manual, that option does not show. It skips from 1-05 to 1-08 in the table...
