db all hookup
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=133046
Printed Date: May 14, 2026 at 8:42 AM
Topic: db all hookup
Posted By: uponone929rr
Subject: db all hookup
Date Posted: December 21, 2012 at 7:47 PM
I Have 2008 Chevy Silverado w/ Factory Remotestart. I am putting a 5501 Viper system in to extend range, I using A DB-ALL, RFLOOP and OBDTHRGM2.  I got an issue.. I go to use the remote start it cycles like it started but it never does ... The remote acts as if it was runing for about a minute then says remote start error.
I have the The power, ground and Neutral saftey hooked up as the dball instructions say to. I have no Idea what the issue is. Any Ideas
Posted By: lurch228
Date Posted: December 24, 2012 at 6:56 AM
Are you trying to use the 5501 to control the factory remote start?
If so the XL202 and the 6711t antenna with a 7752 remote connected to the dball will do everthing you need.
Otherwise with the 5501 you will need to do a complete remote install like there is no factory remote start.
