relays for oem arm/disarm?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=133182
Printed Date: April 01, 2026 at 9:26 PM
Topic: relays for oem arm/disarm?
Posted By: markls
Subject: relays for oem arm/disarm?
Date Posted: January 04, 2013 at 7:31 AM
This is my first post so I hope this question isn't too idiotic. I'm going through some DEI install manuals (Viper 5701, Avital 5303L) and they say the factory arm/disarm (-) should be connected to a relay, even when polarity doesn't need to be changed. Is this a standard requirement? Do factory arm/disarm triggers need that much current? Or am I missing something here? Thanks!
Posted By: chev104275
Date Posted: January 04, 2013 at 8:10 AM
What make and model of vehicle ?
Posted By: markls
Date Posted: January 04, 2013 at 8:25 AM
None at the moment -- just a general question. The DEI manuals say to always use a relay, so I'm just wondering if the OEM arm/disarm is typically a high current application on most vehicles.
Posted By: Mike M2
Date Posted: January 05, 2013 at 6:58 AM
Usually no relay is required for this. Most arm low current and a straight connection from car to alarm is fine...
Mike M2
Tech Manager
CS Dealer Services
Posted By: markls
Date Posted: January 05, 2013 at 8:24 AM
Thanks Mike. That's what I thought -- but figured I'd ask in case I was missing something.
