03 FORD ESCAPE
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=13319
Printed Date: May 14, 2026 at 1:03 PM
Topic: 03 FORD ESCAPE
Posted By: mxxmikexx
Subject: 03 FORD ESCAPE
Date Posted: May 08, 2003 at 3:37 PM
do you have to use a universal transponder box or will a 555f work to bypass the factory transponder in this vehicle? does anyone have any helpful hints/tricks on a remote start/keyless install???
thanks!
Posted By: circus boy
Date Posted: May 09, 2003 at 9:31 AM
you can use the 555s to bypass the chip in the key other then that its a pretty easy car
Posted By: Velocity Motors
Date Posted: May 09, 2003 at 2:48 PM
555F does not work on the 2003 Escape's. You will need to use the universal module for this installation. Not a big deal, just loose a key.
