viper 5904 dball 03 silverado
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=133285
Printed Date: April 07, 2026 at 4:44 PM
Topic: viper 5904 dball 03 silverado
Posted By: bobby speer
Subject: viper 5904 dball 03 silverado
Date Posted: January 12, 2013 at 9:11 PM
DBALL instructions state that when a DBALL is used in D2D, with a Viper, the jumpers on the remote starter must be placed horizontal operating position. Vertical position for W2W? Where are jumpers on 5904?
Also, on 5904, at H1 main harness jack, there is red tape covering two of the pins. Is this tape easily removed?
Thank you, for help!
Posted By: shortcircuit161
Date Posted: January 14, 2013 at 12:10 PM
The jumpers are for older Viper/Python brains that don't apply to the 5904. There are no jumpers needed to connect in D2D.
Not sure if you already removed the red tape but it's pretty easy to pull out.
Good luck!
Date Posted: January 15, 2013 at 10:13 AM
Thank you for reply. Just did not want to destroy something jerking tape.
Posted By: lucasoil4u
Date Posted: January 16, 2013 at 12:32 PM
that tape is so viper knows if the wire harness was ever plugged in.
