04 galant aps787n r/s alarm combo
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=133315
Printed Date: April 06, 2026 at 6:27 AM
Topic: 04 galant aps787n r/s alarm combo
Posted By: mav4000
Subject: 04 galant aps787n r/s alarm combo
Date Posted: January 16, 2013 at 12:57 PM
I am installing an Audiovox Prestige APS787N in a 04 Mitsubishi Galant.I was wondering if there was a bypass module that doesn't require a key that I could use to control door locks and if there was one wire that i could use for door trigger instead of having to diode isolate 4 wires one for each door.
Posted By: kreg357
Date Posted: January 16, 2013 at 1:21 PM
Not a whole lot of bypass modules available for that car.  Your best choice is the Fortin Pats Mitsubishi 2 bypass module.  You will
need two keys to program it but won't need a dealer scan tool or have to leave a key in the car.  See one on EBay for $20.
Posted By: shortcircuit161
Date Posted: January 16, 2013 at 1:27 PM
I was just about to say similar but according to this manual from Fortin, the dealer tool is only needed for 2007 and up models.
https://ifar.ca/en/download/676/pats-mitsubishi-2_installation_guide.rev-m.pdf
All door trigger per Directwire -
Door Trigger      lt. green      -      dash fuse box, top, white 15 pin plug, pin 6
Locks and factory alarm control wiring are very easy to get to right under the dash.
Posted By: mav4000
Date Posted: January 16, 2013 at 3:03 PM
Wow thanks for the quick reply I had my eye on that one but was hoping for something similar to a Gm style bypass where i could connect to OBD2
wire but thanks again for your help.
