451m module 2004 ram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=133462
Printed Date: April 11, 2026 at 8:34 AM
Topic: 451m module 2004 ram
Posted By: ziggyb222
Subject: 451m module 2004 ram
Date Posted: January 29, 2013 at 7:55 AM
On the three pin harness on the 451M door lock module, I know the green and blue are the neg trigger signal from the alarm/remote start. My question is does the red need a constant 12 volts? Been awhile since I worked with a 451m. Thanks in advance!!!!!
Posted By: soundnsecurity
Date Posted: January 29, 2013 at 8:02 AM
yes
Date Posted: January 29, 2013 at 8:05 AM
Thanks... just found all my notes.... I am getting old...LOL
Posted By: howie ll
Date Posted: January 29, 2013 at 9:01 AM
If you're working with DEI product, that centre pin is at a constant 12V+ to feed the red anyway. No need to connect to a constant, it's already there.
NOT the case with A/Vox products although Comp. may be the same.
Posted By: lucasoil4u
Date Posted: January 29, 2013 at 1:02 PM
YES YOU NEED POWER!!
